Warning: include(/home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/composer/../stellarwp/schema/src/Schema/Tables/Contracts/Table.php): Failed to open stream: No such file or directory in /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/composer/ClassLoader.php on line 576
Warning: include(): Failed opening '/home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/composer/../stellarwp/schema/src/Schema/Tables/Contracts/Table.php' for inclusion (include_path='.:/usr/share/php') in /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/composer/ClassLoader.php on line 576
Deprecated: Method ReflectionProperty::setAccessible() is deprecated since 8.5, as it has no effect since PHP 8.1 in /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/lucatume/di52/src/ContainerException.php on line 35
Deprecated: Method ReflectionProperty::setAccessible() is deprecated since 8.5, as it has no effect since PHP 8.1 in /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/lucatume/di52/src/ContainerException.php on line 57
Fatal error: Uncaught TEC\Common\Exceptions\Not_Bound_Exception: Error while making TEC\Common\StellarWP\Shepherd\Tables\AS_Logs: class TEC\Common\StellarWP\Schema\Tables\Contracts\Table not found. in /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Common/Contracts/Container.php:35 Stack trace: #0 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/stellarwp/shepherd/src/Config.php(113): TEC\Common\Contracts\Container->get() #1 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/stellarwp/shepherd/src/Provider.php(72): TEC\Common\StellarWP\Shepherd\Config::get_logger() #2 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/lucatume/di52/src/Container.php(427): TEC\Common\StellarWP\Shepherd\Provider->register() #3 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Common/Contracts/Container.php(63): TEC\Common\lucatume\DI52\Container->register() #4 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Common/Libraries/Shepherd.php(35): TEC\Common\Contracts\Container->register() #5 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Common/Contracts/Provider/Controller.php(49): TEC\Common\Libraries\Shepherd->do_register() #6 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/lucatume/di52/src/Container.php(427): TEC\Common\Contracts\Provider\Controller->register() #7 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Common/Contracts/Container.php(63): TEC\Common\lucatume\DI52\Container->register() #8 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Common/Libraries/Provider.php(50): TEC\Common\Contracts\Container->register() #9 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/vendor/vendor-prefixed/lucatume/di52/src/Container.php(427): TEC\Common\Libraries\Provider->register() #10 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Common/Contracts/Container.php(63): TEC\Common\lucatume\DI52\Container->register() #11 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Tribe/Container.php(311): TEC\Common\Contracts\Container->register() #12 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Tribe/Main.php(848): tribe_register_provider() #13 /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Tribe/Main.php(122): Tribe__Main->bind_implementations() #14 /home/xmclub/web/xmclub.nl/public_html/wp-includes/class-wp-hook.php(353): Tribe__Main->plugins_loaded() #15 /home/xmclub/web/xmclub.nl/public_html/wp-includes/class-wp-hook.php(377): WP_Hook->apply_filters() #16 /home/xmclub/web/xmclub.nl/public_html/wp-includes/plugin.php(523): WP_Hook->do_action() #17 /home/xmclub/web/xmclub.nl/public_html/wp-settings.php(630): do_action() #18 /home/xmclub/web/xmclub.nl/public_html/wp-config.php(104): require_once('...') #19 /home/xmclub/web/xmclub.nl/public_html/wp-load.php(50): require_once('...') #20 /home/xmclub/web/xmclub.nl/public_html/wp-blog-header.php(13): require_once('...') #21 /home/xmclub/web/xmclub.nl/public_html/index.php(17): require('...') #22 {main} thrown in /home/xmclub/web/xmclub.nl/public_html/wp-content/plugins/the-events-calendar/common/src/Common/Contracts/Container.php on line 35
